I’m trying to setup led labels using the screen editor to show things like limit switch status and way lubricant pump status.
I am trying to have the font color change when the switch is triggered. For whatever reason it works on one of them but doesn’t work on the others. The only it works on is something that is actually an output that is controlled by one of the kflop threads. Is this generally supported?
“Led” labels
Re: “Led” labels
Ok, so I figured out that it does more or less what I want if I make the style as a toggle button instead of a label. I would assume some of the other button types might work similarly.
