KMotion CNC 5.3.3
Chevvron
KMotion CNC 5.3.3
Post by Chevvron » Fri Jul 05, 2024 2:13 pm
Kogna running KMotion CNC 5.3.3
Same init & mot files as runs on 435f no problem.
Only running 1 axis as KFlop (which is now at a different location) is used to test drives and motors.
G code program runs motor as expected.
Problem is only 1 jog button works on initial KMotion launch, other direction does not move motor.
After 1st jog both buttons then do not jog motor.
Keyboard arrow buttons do not jog motor.
Step works both directions okay.
PC is running Windows 7.
Could this be the issue ?
Tim
Re: KMotion CNC 5.3.3
Post by TomKerekes » Fri Jul 05, 2024 4:28 pm
Hi Tim,
Please delete any Kinematics.txt file to see if that is related to the issue.
Running KMotion.exe are there any Console Messages?
What does the Axis Screen show before and after the Jog?
Please post your Initialization C Program.
I doubt if W7 would be the issue.
Chevvron
Post by Chevvron » Sun Jul 07, 2024 2:18 pm
Attached init file 435f as used with KFlop.
Attached init file 533 as used with Kogna.
No Console messages displayed.
No Kinematics.txt file.
Tim
1AX_ENC_Init - 533.c
(1.55 KiB) Downloaded 186 times
1AX_ENC_Init - 435f.c
(6.67 KiB) Downloaded 185 times
Chevvron
Post by Chevvron » Sun Jul 07, 2024 3:54 pm
I have found the error i have made, confusing channels with axes.
Attached is the init file that jogs both directions.
1AX_ENC_Init_533 ok.c
(1.56 KiB) Downloaded 180 times
Post by TomKerekes » Mon Jul 08, 2024 12:31 am
Hi Tim,
That is a good workaround but Axes >= 8 should work correctly. This will be fixed in the next Version.
