S command doesn't work properly
BepsIt
Post by BepsIt » Fri Apr 19, 2019 10:23 am
good morning to all,
i just switched the Mill from Mach3 Cnc to KmotionCnc. All is working well but I have some problems with the Spindle; this is the configuration:
-) Spindle's inverter is configured as -5V=>3000Rpm
-) Spindle's Axis is #7, No Input, DAC Servo, Output Gain 1
-) M3, M4, M5, S are calling the C programs as explined into the Help/KMotionCNC/SpindleControl.htm
-) in the MySpindleDefs.h C program I changed the SPINDLEAXIS, SPINDLECW and SPINDLECCW_BIT_BIT in accordance with my hardware
-) the used KmotionCnc screen layout is DualPane3AxisSplit1024x768.scr
Everything is working normally except the S command: M3, M4 and M5 are working and the Spindle start, reverse and stop in accordance with buttons but the S command doesn't change anything. Opening Analog Status I read a fixed value around -1V on DAC #7 and if i change S, the DAC value doesn't change. But i can see from Console that the count per sec are changed.
Have u an idea where I am wrong?
Beppe
Re: S command doesn't work properly
Post by TomKerekes » Fri Apr 19, 2019 5:37 pm
Hi Beppe,
Do you have KFLOP Axis #7 configured to use DAC #7?
If you Jog Axis #7 from the Console Screen does the Speed Change. Ie. Jog7=10000
If you Post your S Program, MySpindleDefs.h, and a screen shot of how you have S configured in KMotionCNC | Tool Setup we can check it over
BepsIt
Post by BepsIt » Fri Apr 19, 2019 6:14 pm
tks Tom for the reply.
Now here is night, tomorrow morning i will go to warehouse and i will keep all you request
Beppe
BepsIt
Post by BepsIt » Fri Apr 19, 2019 6:53 pm
While waiting I send the requested, can you let me to well understand two things? In particular:
1) in KmotionCnc Tool setup screen, M0-M30 folder, button set as "Execute Prog", the VAR field witch value must to assume?
2) configuring Z axis I had following error due too low axis acceleration; I increased the Accel value in Tool setup screen/Trajectory planner but
noything changed, only when i changed the Accel value in the Init program was the problem solved: is it correct to suppose that the Trajectory
planner Accel value is influent only when smaller than Init Accel value?
Beppe
Post by TomKerekes » Fri Apr 19, 2019 7:12 pm
Hi Beppe,
The Var field must match the C Program. Normally 113 as set by:
#define PC_COMM_CSS_S 113 // S speed setting in inches/sec
no, the KFLOP Init Program settings affect Jogging and Rapids. The Trajectory Planner settings have an effect while feeding. See this article.
BepsIt
Post by BepsIt » Sat Apr 20, 2019 7:54 am
good morning Tom,
attached my setting files. Jog command doesn't change Spindle speed, S command in KmotionCnc change the jogging speed but the Dac has the same value.
Waiting your suggestion...
Beppe
Console and Analog status
Channel 7 configuration
S configuration in Tool setup
SpindleJog.c
(1020 Bytes) Downloaded 131 times
MySpindleDefs.h
(645 Bytes) Downloaded 119 times
Post by TomKerekes » Sat Apr 20, 2019 5:20 pm
Hi Beppe,
If Jogging Axis 7 doesn't move the Spindle then Axis 7 is not configured properly or Axis 7 is not enabled.
Is Axis #7 Enabled? Check the Axis Screen.
How is Axis #7 configured. See the Config/Flash, Step Response, and Filters Screen. It should be configured as described here.
Instead of photos of screens it is better to grab screen shots using Alt-PrintScreen, paste to paint.exe, crop, save as *.png file.
BepsIt
Post by BepsIt » Sat Apr 20, 2019 6:14 pm
hi Tom,
in the Channel 7 configuration picture I sent before do you see something wrong? I uploaded from Kflop the configuration then I am sure about channel 7 status. In the picture below you can see that axis #7 is enabled. Did you ceck my C configuration files? It's all as requested?
BepsIt
Post by BepsIt » Sat Apr 20, 2019 6:41 pm
attached the Init C fil, so you can check if I have wrong configuration
Beppe
init_new.c
(8.94 KiB) Downloaded 131 times
Post by TomKerekes » Sat Apr 20, 2019 7:32 pm
Hi Beppe,
Axis #7 is not configured properly with regard to the Step Response Screen Parameters FF and PID. Please read the link in my last post.
