- 2 Overview
- 3 Kinematics3Rod
- 8 5 Axis Gimbal CB by Forum User kizilkaya
G0 B0 (start at angle 0)
G1 B90 (rotate B 90 degrees).
Overview
Kinematics3Rod
// Kinematics3Rod.cpp: implementation of the CKinematics3Rod class. // ////////////////////////////////////////////////////////////////////// #include "stdafx.h" #include "Kinematics3Rod.h" #define sqr(x) ((x)*(x)) ////////////////////////////////////////////////////////////////////// // Construction/Destruction ////////////////////////////////////////////////////////////////////// CKinematics3Rod::CKinematics3Rod() { Act0Center.x = 12; Act0Center.y = 0; Act0Center.z = 0; Act1Center.x = 0; Act1Center.y = 12; Act1Center.z = 0; Act2Center.x = 11; Act2Center.y = 3; Act2Center.z = 12; // when actuator position is zero this is how long the rod is Act0Off = sqrt(sqr(Act0Center.x) + sqr(Act0Center.y) + sqr(Act0Center.z)); Act1Off = sqrt(sqr(Act1Center.x) + sqr(Act1Center.y) + sqr(Act1Center.z)); Act2Off = sqrt(sqr(Act2Center.x) + sqr(Act2Center.y) + sqr(Act2Center.z)); m_MotionParams.MaxLinearLength = 0.25; // limit the segment lengs for nonlinear systems m_MotionParams.MaxRapidFRO = 1.0; // limit the increase in Rapid HW FRO m_MotionParams.UseOnlyLinearSegments=true; } CKinematics3Rod::~CKinematics3Rod() { } int CKinematics3Rod::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo) { // find lengths of each actuator GeoCorrect(x,y,z,&x,&y,&z); double r0 = sqrt(sqr(x-Act0Center.x) + sqr(y-Act0Center.y) + sqr(z-Act0Center.z)) - Act0Off; double r1 = sqrt(sqr(x-Act1Center.x) + sqr(y-Act1Center.y) + sqr(z-Act1Center.z)) - Act1Off; double r2 = sqrt(sqr(x-Act2Center.x) + sqr(y-Act2Center.y) + sqr(z-Act2Center.z)) - Act2Off; Acts[0] = r0*m_MotionParams.CountsPerInchX; Acts[1] = r1*m_MotionParams.CountsPerInchY; Acts[2] = r2*m_MotionParams.CountsPerInchZ; Acts[3] = a*m_MotionParams.CountsPerInchA; Acts[4] = b*m_MotionParams.CountsPerInchB; Acts[5] = c*m_MotionParams.CountsPerInchC; return 0; } // perform Inversion to go the other way int CKinematics3Rod::TransformActuatorstoCAD(double *Acts, double *xr, double *yr, double *zr, double *ar, double *br, double *cr, bool NoGeo) { return InvertTransformCADtoActuators(Acts, xr, yr, zr, ar, br, cr); }
Formulas to calculate Actuator Positions from XYZABC CAD Position uses Rotate3 function to rotate a point through 3 angles.
int CKinematicsGeppettoExtrude::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo) { double x_0,y_0,z_0,x_1,y_1,z_1,x_2,y_2,z_2,x_3,y_3,z_3,x_4,y_4,z_4,x_5,y_5,z_5, TCP_Rotated_x,TCP_Rotated_y,TCP_Rotated_z; // find lengths of each actuator // Determine where the TCP rotated point would be relative to origin when oriented at the desired angles. Rotate3(0, 0, 0, m_MotionParams.TCP_X, m_MotionParams.TCP_Y, m_MotionParams.TCP_Z, a, b, c, &TCP_Rotated_x, &TCP_Rotated_y, &TCP_Rotated_z); // Translate from TCP to end effector origin x += TCP_Rotated_x - m_MotionParams.TCP_X; y += TCP_Rotated_y - m_MotionParams.TCP_Y; z += TCP_Rotated_z - m_MotionParams.TCP_Z; if (!NoGeo) GeoCorrect(x,y,z,a,b,c,&x,&y, &z, &a, &b, &c); // Find where connection points should be Rotate3(x,y,z,x+X0,y+Y0,z+Z0,a,b,c,&x_0,&y_0,&z_0); Rotate3(x,y,z,x+X1,y+Y1,z+Z1,a,b,c,&x_1,&y_1,&z_1); Rotate3(x,y,z,x+X2,y+Y2,z+Z2,a,b,c,&x_2,&y_2,&z_2); Rotate3(x,y,z,x+X3,y+Y3,z+Z3,a,b,c,&x_3,&y_3,&z_3); Rotate3(x,y,z,x+X4,y+Y4,z+Z4,a,b,c,&x_4,&y_4,&z_4); Rotate3(x,y,z,x+X5,y+Y5,z+Z5,a,b,c,&x_5,&y_5,&z_5); double r0 = sqrt(sqr(x_0 - Act0Center.x) + sqr(y_0 - Act0Center.y) + sqr(z_0 - Act0Center.z)) - Act0Off; double r1 = sqrt(sqr(x_1 - Act1Center.x) + sqr(y_1 - Act1Center.y) + sqr(z_1 - Act1Center.z)) - Act1Off; double r2 = sqrt(sqr(x_2 - Act2Center.x) + sqr(y_2 - Act2Center.y) + sqr(z_2 - Act2Center.z)) - Act2Off; double r3 = sqrt(sqr(x_3 - Act3Center.x) + sqr(y_3 - Act3Center.y) + sqr(z_3 - Act3Center.z)) - Act3Off; double r4 = sqrt(sqr(x_4 - Act4Center.x) + sqr(y_4 - Act4Center.y) + sqr(z_4 - Act4Center.z)) - Act4Off; double r5 = sqrt(sqr(x_5 - Act5Center.x) + sqr(y_5 - Act5Center.y) + sqr(z_5 - Act5Center.z)) - Act5Off; Acts[0] = r0*m_MotionParams.CountsPerInchX; Acts[1] = r1*m_MotionParams.CountsPerInchY; Acts[2] = r2*m_MotionParams.CountsPerInchZ; Acts[3] = r3*m_MotionParams.CountsPerInchA; Acts[4] = r4*m_MotionParams.CountsPerInchB; Acts[5] = r5*m_MotionParams.CountsPerInchC; return 0; }
Origin Definition
The Solution
The formula in C++ code:
// Kienematics for Table with A Axis and Tool Gimble head with B Axis // // A axis always rotates about X axis // B axis always rotates about Y axis int CKinematics5AxisTableAGimbalB::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo) { double Xt, Yt, Zt, Xa, Ya, Za, ToolXR, ToolZR, ChuckXR, ChuckZR, Dummy; if (m_MotionParams.TCP_Active) { //Find CAD Tool Tip Location from coordinate passed in (Xt, Yt, Zt) Xt = x - m_MotionParams.TCP_X; // remove tool offset Yt = y - m_MotionParams.TCP_Y; Zt = z - m_MotionParams.TCP_Z; //Perform A rotation to obtain (Xa, Ya, Za) Rotate3(0, 0, 0, Xt, Yt, Zt, a, 0, 0, &Xa, &Ya, &Za); //Determine ChuckXR ChuckZR by rotating PivotChuckLength by Angle B Rotate3(0, 0, 0, 0, 0, PivotToChuckLength, 0, -b, 0, &ChuckXR, &Dummy, &ChuckZR); //Determine Rotated Tool offset ToolXR ToolZR by rotating ToolX ToolZ by Angle B Rotate3(0, 0, 0, m_MotionParams.TCP_X, m_MotionParams.TCP_Y, m_MotionParams.TCP_Z, 0, -b, 0, &ToolXR, &Dummy, &ToolZR); x = Xa + ToolXR + ChuckXR; y = Ya; z = Za + ToolZR + ChuckZR - PivotToChuckLength; } if (!NoGeo) GeoCorrect(x,y,z,&x,&y, &z); Acts[0] = x*m_MotionParams.CountsPerInchX; Acts[1] = y*m_MotionParams.CountsPerInchY; Acts[2] = z*m_MotionParams.CountsPerInchZ; Acts[3] = a*m_MotionParams.CountsPerInchA; Acts[4] = b*m_MotionParams.CountsPerInchB; Acts[5] = c*m_MotionParams.CountsPerInchC; return 0; }
Geometry below
Class name CKinematicsScara
Simulation
Forum Thread here.
3 Axis Cable Delta Robot by Александр Украинец==
Project Details
Class Name CKinematicsGimbalCB
Here is an RTCP Guide submitted by kizilkaya
There is a lot of complicated information about RTCP and it took me a long time to collect all this and deliver the machine to my customer, but I finally succeeded. RTCP works without any problems. I have prepared a detailed guide for those who do not want to experience difficulties like me. I would be happy if you share it.
STEP 1 ) Adjust all axis settings very precisely, especially the angled axes.
STEP 2 ) Kinematics.txt from Data.rar copy to C:\KMotion5.3.4\GCodeInterpreter
STEP 3 ) Select Kinematic from Kinematics.txt according to your machine configuration. (e.g. Kinematics5AxisGimbalCB).
STEP 4 )B and C axis positions must be set to "0 (zero)" as shown in the picture, otherwise the angled axes will tilt in different directions when RTCP is active.
STEP 5 ) Open the C:\KMotion5.3.4\GCodeInterpreter\GCodeInterpreter.vcxproj file with Visual Studio and set the pivot as seen in the pivot.png image, then compile the project and create the GCodeInterpreter element.
Now you can use rctp actively with "G43.4 Hx (x tool number)" and turn off rtcp with "G49".
Example ;
Please first pull the x, y and z axes (taking the pivot length into consideration) to a safe area and edit the g code according to the C and B axis limits.
G43.4 H1 G1 F3000 B0 C0
B90
B-90
C-180
C180
B0 C0
M30
Download Project Files
