Revision as of 16:38, 15 October 2015 by TK (Talk | contribs)
Find and share information on Dynomotion Systems.  Please feel free to contribute and correct information yourself.  Joining is not required to view or search for information, however you will need to register and confirm your email account before you can edit or add pages.  By default, a WYSIWYG editor is enabled to make editing pages easier.  Standard MediaWiki editing may also be used or set as the default in your User Preferences.  We recommend saving your work as you add pages to prevent loss of information due to potential system errors.
Creating New Wiki Pages
To create a new wiki page (after registering for an account) you can add a link with a new name to the page you would like to create.  The link will appear in red to indicate it links to a page that doesn't yet exist.  Click on the link and you will be prompted to create the page.
Installation
Board Info
V4.33q
  5. Right Mouse Click "Paste"
  7. Save the file
