Revision as of 13:06, 8 November 2015 by TK (Talk | contribs)
Tests to find optimal settings for both types of moves should be made using the Step Response Screen.  The Step Response Screen always performs 3rd order motion but 2nd order motion can be simulated by temporarily setting the Jerk to a huge value (1000X the acceleration value).  In general reducing the Jerk value will result in longer times to perform motions, but often the improved smoothness will permit higher maximum accelerations and velocities to be used resulting in overall shorter motion times.
