Gaming control set up
Hotrodjohn
I plugged in a Logitech 310 gaming control. My question is are there any set up options or it just is what it is? I can’t seem to find touch off z and one of the buttons causes a disconnect loosing x y z.......
Re: Gaming control set up
Hi Hotrodjohn,
The Gamepad should work as described here. There aren't any configurable options without changing the KMotionCNC Source Code. I'm not sure why you would get a disconnect. What is your configuration? What button are you pushing?
Hotrodjohn
I guess it’s the emergency stop on the left. So no touch off z available on controller?
That should disable the axes not disconnect.I guess it’s the emergency stop on the left.
Not without changing the KMotionCNC Source Code.So no touch off z available on controller?
