Sometime in the near future i will be starting on adding a carousel tool changer to my Hurco mill. Right now i am looking into how to automate it. Thinking of doing this with a PLC or adding another Konnect board. One question i have is the specs for Konnect output says .25mA up to 6W. Is this total or per output? Currently looks like there will be about 5 air solenoids and a couple relays along with sensors and switches to operate tool changer.
Troy
Konnect Tool Changer
Re: Konnect Tool Changer
Hi Troy,
Sounds like fun.
The outputs are conservatively rated at 25V @ 0.25 Amps (not ma) per output.
Please remember to put reverse flyback diodes across any solenoid or relay coils.
Sounds like fun.
The solenoids iam planing to use are 24VDC 3w, so i should be safe then. Will most likely add another Konnect. The price alone is a little cheaper than adding a plc with enough I/Os. And will also allow Kflop/Kmotion to handle everything.
Noted on flybacks.
Thanks again,
Troy
Noted on flybacks.
Thanks again,
Troy
