Shortcuts to Kmotion Axes Jog for B, C, U, V
AmitKumar171
Post by AmitKumar171 » Thu Sep 20, 2018 2:08 pm
Hi All,
I am using KMotion Board. And in KmotionCNC software there are jog buttons are there respectively for X, Y, Z, A, B, C axes.
And Shortcut Commands are there for Step/Fast Jog Only 4 of 8 axes. like X, Y, Z, A.
How do i add more shortcuts to drive axes like B, C, U, V to Step/Fast Jog similar to Ctrl+Jog or Shift+Jog Keyboard Shortcuts. ?
Please help me in with this regards.
Thank You
AMIT KUMAR
Re: Shortcuts to Kmotion Axes Jog for B, C, U, V
Post by TomKerekes » Thu Sep 20, 2018 4:42 pm
Hi Amit,
We only have Jog Buttons for XYZABC. You can assign Hot Keys for the BC axes with the Screen Editor. All 3 buttons for the axis direction must be assigned the same Hot Key.
We don't have Jog Buttons for the UV axis. You could do basic Jogging of those axes using a momentary button to set a Virtual Bit. Then create a C Program to monitor the Virtual Bit and Jog the axis when the bit turns on and stop the axis when the bit turns off.
AmitKumar171
Post by AmitKumar171 » Fri Sep 21, 2018 9:39 am
Thanks for the reply as you have said earlier I did edited KmotionCNCscreen editor to use DIVIDE KEY and MULTIPLICATION KEY to set keyboard jog for my c axis. I have set the key according to the sceenshot attached. But i am not able to run the C axis with above keyboard buttons.
Is there any other changes than screen editor
Hot keys 111 and 106 respectively. I want to set those keys to jog my C axis similar to X,Y,Z,A. As in picture i already set it in screen editor but it is not working.
Please help me to add a jog button for C axis.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Post by TomKerekes » Fri Sep 21, 2018 5:24 pm
Hi Amit,
It seems to work fine for me.
Did you set all 3 buttons to the same hotkey?
Did you push the "Set" button?
Is "Keyboard Jog" enabled?
Are there any duplicate Hot Keys defined"
Attached is a working example.
CAxisJogCMulDiv.scr
(47.46 KiB) Downloaded 296 times
AmitKumar171
Post by AmitKumar171 » Mon Sep 24, 2018 5:50 am
Thanks for your reply.
I have done that. and i have seen your post in that KmotionCNCdlg file there is an option to set axes from 4 to 6 then it will work.
And it is working fine to me.
Thank You
AMIT KUMAR
