Hello.
Any idea what this error is?
It comes when i send any gcode command from Kmotioncnc.
Version 435g.
The Kmotion console does not show anything, when this error comes.
Required parameter missing
- Screenshot_20230112_093031.png (7.88 KiB) Viewed 5073 times
Re: Required parameter missing
The GCode Interpreter saves/restores GCode Variables/Parameters into a file specified in Tool Setup | Tool/Setup Files | Vars file. See here. If unspecified the file emc.var is used.
This file lists which variables are to be saved/restored along with their value. Certain variables must be specified to be saved/restored (mainly the parameters used for GCode Offsets). Others are optional. If the mandatory variables are not specified this error is displayed.
Is your Var file missing? Have you changed it? Is it corrupted?
Here is a list of the mandatory parameters:
This is an array of the index numbers of system parameters that must
be included in a file used with the rs274ngc_restore_parameters
function. The array is used by that function and by the
rs274ngc_save_parameters function.
static const int _required_parameters[] = {
5161, 5162, 5163, /* G28 home */
5164, 5165, 5166,
5181, 5182, 5183, /* G30 home */
5184, 5185, 5186,
5211, 5212, 5213, /* G92 offsets */
5214, 5215, 5216,
5220, /* selected coordinate */
5221, 5222, 5223, /* coordinate system 1 */
5224, 5225, 5226,
5241, 5242, 5243, /* coordinate system 2 */
5244, 5245, 5246,
5261, 5262, 5263, /* coordinate system 3 */
5264, 5265, 5266,
5281, 5282, 5283, /* coordinate system 4 */
5284, 5285, 5286,
5301, 5302, 5303, /* coordinate system 5 */
5304, 5305, 5306,
5321, 5322, 5323, /* coordinate system 6 */
5324, 5325, 5326,
5341, 5342, 5343, /* coordinate system 7 */
5344, 5345, 5346,
5361, 5362, 5363, /* coordinate system 8 */
5364, 5365, 5366,
5381, 5382, 5383, /* coordinate system 9 */
5384, 5385, 5386,
RS274NGC_MAX_PARAMETERS
};Regards,
Thank you for the quick reply. The file somehow was there, but with no data.
In the error window, it would be a good idea, to say something like "Recuired parameter missing, in file vars"
Regards.
Regards.
