How to get last machine coordinate after power off and on
AmitKumar171
Post by AmitKumar171 » Tue Aug 25, 2020 6:55 am
HI tom,
I am using Kflop+KANALOG for my Machine.
I am using Leadshine AC servo motors and driver as below.
http://www.leadshine.com/UploadFile/Dow ... 200603.pdf
and i have a 400w motor for above drivers that is having 17 bit absolute encoder.
I want to save last position of encoder in terms of machine coordinates in kflop.
As whenever i am doing init command my encoder coordinates (blue) and machine coordinates (orange) becomes zero.
But i want to retain the old position of the motor before init.
OR something similar to close loop control using KFLOP+KANALOG analog output control servo. ?
init program should not zero all axis, init program should give current absolute encoder position. ?
i want help in above problem.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Re: How to get last machine coordinate after power off and on
Post by TomKerekes » Tue Aug 25, 2020 5:29 pm
Hi Amit,
Then don't Zero the Axis in the Init Program. Post your init c program for us to check.
