Usb problem
aaperezd
Usb problem
Post by aaperezd » Wed Feb 26, 2020 3:15 pm
Hi friends, im Alberto From Chile,
I have tried to connect my kflop through usb but it does not connect, there is a half-second loop where it tries to connect kflop, my laptop detects it then disconnects and then reconnects it and so it repeats, the current configuration is :
kflop + kanalog + konnect.
perform many tests, among them just connect kflop, put jumper 3 and remove the power of 12 volts, but nothing works, what could it be?
Thanks a lot
Re: Usb problem
Post by TomKerekes » Wed Feb 26, 2020 6:20 pm
Hi Alberto,
How are you applying +5V to KFLOP? What are the +5V power supply specifications? USB power is not sufficient when using Kanalog. Remove Jumper J3.
