I try to figure how to change a value of a edit box in the screeneditor with a c program.
Change value of a edit box in the screeneditor with a c program
4minnovations
Re: Change value of a edit box in the screeneditor with a c program
An Edit Control is normally used for Operator Input. There is only a method of reading the Control not writing. Why do you need to change the value from a C Program?
4minnovations
I have a value that I need in two different screen. This value is calculated, but the user can mdoify them.
Hi 4minnovations,
Here is a patch for V4.35b that should allow setting Text in an Edit Control. It also includes some other patches (More unicode support for controls, combo box controls, and the Set DRO to half option).
New KMotionCNC.exe copy to \KMotion435b\KMotion\Release
New KflopToKMotionCNCFunctions.c which includes new SetEditControl function copy to \KMotion435b\C Programs
Example C Program to set an Edit Control Text
Sources if needed.
char s[80];
// Convert number to string
sprintf(s,"%g",123.4);
// Put it onto the Screen
SetEditControl(1000, 160, s);
4minnovations
Thanks Tom,
it's work perfectly.
