Hi Raffaello,
Try this Debug64 Version
KOGNA read I/O bit from main status
Re: KOGNA read I/O bit from main status
- KMotion_dotNet.dll
- (194 KiB) Downloaded 1111 times
thanks for the file, but I get always the same problem
I tested it in my project and in your SimpleFormsCS, but BitState200 come as 2 length array
Raffaello
Raffaello
Hi Raffaello,
It shows a 3 element array and works for me.
It seems you are using an old dll. I asked you to delete the dll to see if you get an error but you never responded respond.
I tried to delete or rename file, also I deleted all the reference to the projet et give the new one, clean and rebuild the wole solution more times but it didn't work!
So I have try to create a brand new projet and put as reference the new dll and this time it works!
So, definitely the problem come from the setup of my main project.
Thanks for your support, if you have some suggestions, I'm hearing!
Good day
Raffaello
Good day
Raffaello
I've had issues with VS referencing the wrong directory, and had to manually edit one of the project config files.
It seems to be that some settings get created by VS (possibly during project creation), which you then can't change within VS (or at least I couldn't find them!).
My problem was my project originally targeted 4.3x, and updating to 5.3.0 caused it to still use the 4.3x directory, despite updating every setting I could find within VS. In the end I done a text search of the project directory, and it turned up a setting that still pointed to 4.3x.
Having just looked at my notes, it was the <StartWorkingDirectory> setting within the .csproj.user file.
Yes!!!
Me to I started whit 4.3x, and i find in .csproj file a wrong link to the old folder.
Now it works like a charm
Thanks Moray!
Raffaello
Thanks Moray!
Raffaello
