Resurrecting an old project
Re: Resurrecting an old project
Post by TomKerekes » Mon Jan 27, 2020 5:27 pm
Hi Art,
SWE would not normally be appropriate as that comes on after KFLOP/Kanalog Boots not when Mach3/KMotionCNC is initialized and the servos are enabled.
I don't have any idea why a wiring a relay would cause a reset, reboot, or disconnect. Any relay with a coil should have a reverse diode to avoid a high reverse voltage (spark) when it is turned off.
You might turn off a KFLOP LED so you can determine if KFLOP is being reset (and the LED would be turned back on) or the PC is disconnecting the USB.
FlyingScot
Post by FlyingScot » Mon Jan 27, 2020 6:25 pm
Hi Tom
I forgot that I had changed from SWE to Fet 0 O/P and I have a diode across the relay. I have also moved the relay from the kflop enclosure to be close to the drives.
I am not sure what you mean by turning off a kflop led?
Art
Post by TomKerekes » Mon Jan 27, 2020 6:55 pm
Hi Art,
Placing
ClearBit(46);
In your Initialization C Program will turn off one of the LEDs on KFLOP. If the LED comes back on you will know KFLOP rebooted.
FlyingScot
Post by FlyingScot » Mon Jan 27, 2020 7:19 pm
Hi Tom
Yep Kflop rebooted relay dropped out.
Going to try a separate 5v power supply incase there is a drop in 5v when relay triggers. (Its not visible on meter and I don't have my scope handy)
Art
FlyingScot
Post by FlyingScot » Mon Jan 27, 2020 9:19 pm
Thanks Tom
Problem solved it was due to using a dual power supply 5v and 24v.
Now using individual supplies and all seems well.
Art
