Hi all
I am using kflop board.
In Kmotion CNC there is a Run time option in Caption bar of Kmotion cnc here it is shown.
This run time i wan to print somewhere else using DRO Label on my KmotionCNC screen.
I want to know that how to use a DRO Label for printing Run Time.
Waiting for your kind reply.
For printing runtime other then caption bar of KmotionCNC
AmitKumar171
Thank You
AMIT KUMAR
AMIT KUMAR
Re: For printing runtime other then caption bar of KmotionCNC
Hi Amit,
Here is C Program that monitors whether a Job is Active, Time stamps when a Job Starts, detects when a Job Ends, Formats a Job Time message, and writes it to a DROLabel.
Attached is a Screen Script example (also Attached)with the DROLabel that looks like this:
void ServiceJobTimer(void);
#define JOBTIMEPERSIST 162
for (;;)
ServiceJobTimer();
// Monitor and time Jobs starting and ending
static BOOL WasActive = FALSE;
static double StartTime;
double dt, Seconds;
int Hours, Minutes;
char s[80];
if (JOB_ACTIVE && !WasActive) // Started ??
StartTime = Time_sec();
WasActive = TRUE;
if (!JOB_ACTIVE && WasActive) // Ended ??
WasActive = FALSE;
dt = Time_sec() - StartTime;
Hours = (int)(dt / 3600.0);
Minutes = (int)((dt - Hours * 3600.0) / 60.0);
Seconds = dt - Hours * 3600.0 - Minutes * 60.0;
if (Hours > 0)
sprintf(s, "Last Run Time %d hours %d min %5.1f sec", Hours, Minutes, Seconds);
else if (Minutes > 0)
sprintf(s, "Last Run Time %d min %5.1f sec", Minutes, Seconds);
sprintf(s, "Last Run Time %5.1f sec", Seconds);
// Put it onto the Screen using Persist
DROLabel(1000, JOBTIMEPERSIST, s);
- RawCustomWithJobTimeDRO.scr
- (45.72 KiB) Downloaded 296 times
- ServiceJobTimer.c
- (1.3 KiB) Downloaded 321 times
AmitKumar171
Thanks for the reply.
The timer for printing runtime other then caption bar is working fine as expected by the program that you sent.
Will let you know about further updates.
Thank You
AMIT KUMAR
AMIT KUMAR
