i got no G viewer
Re: i got no G viewer
i changed from my custom screen to the basic 2 axis lathe. got the tool path but of course the tool is backwards
on the g code viewer. if i am in basic 2 axis lathe and there is no function to adjust a Y axis value, why is there an elevation difference from the toolpath and the tool? i would think they would be the same plane?
ok, i found the backwards on the radius in my post processor again.
somehow i can edit in the c gode window too.
my Y axis hovering tool in the g code viewer does remain though. i downloaded a new kmotion cnc on my office desktop and it does not do that. not sure what it is
my working PPR again
TITLE:
:T1 = {
CNC Lathe
Mach3 Radius Mode Post
G32 type threading
Modified by Steve Blackmore 06/04/05
:T2 = {
Added Mach3 Constant surface speed support 30/01/05
Added G83 peck drilling 02/03/05
New tool format support added 27/07/05
Altered M6 to follow tool select 24/12/05
END:
VERSION:
FILEVERSION 11.0 TURNING
END:
WORDS:
:TMP = {DDDDDD.dd}
:BLOCK = {"N"DDDD" "}
:XAXIS = {"Z"DDDDD.ddd" "} {"Z"DDD.dddd" "}
:YAXIS = {"X"DDDDD.ddd" "} {"X"DDD.dddd" "}
:XARC = {"K"DDDDD.ddd" "} {"K"DDD.dddd" "}
:YARC = {"I"DDDDD.ddd" "} {"I"DDD.dddd" "}
:ARAD = {"R"DDDDD.ddd" "} {"R"DDD.dddd" "}
:DELAY = {"G04 P"DDD" "}
:DWELL = {"P"DDDD.dddd" "}
:PECK = {"Q"DDDDD.ddd" "} {"Q"DDD.dddd" "}
:NDEEP = {"Q"DDDDD.ddd" "} {"Q"DDD.dddd" "}
:RPLANE = {"R"DDDDD.ddd" "} {"R"DDD.DDDD" "}
:FEED = {"F"DDDDD.dddI" "} {"F"DDD.dddd" "}
:SPIN = {"S"DDDD" "}
:TOOL = {"T"ZDD}
:SUBPR = {"P"DDDD" "}
:REPEAT = {"L"DDDD" "}
:CRC = {"D"DD" "}
:TLC = {""ZDD" "}
:SURF = {"S"DDDD" "}
:SRAD = {"R"DDDD.ddI} {"R"DD.ddddI}
:INDEX = {"INDEX"DDD.ddd" "}
:PROGNO = {"O"DDDDD" "}
:NUM1 = {" "DDDD.dddd" "}
:ROT = {" "DD" "}
:TOOLD = {DDDDD.ddd} {DDD.dddd}
END:
AXES:
YSCALE 1
XSCALE 1
TURRET
END:
GROUPS:
:G1 = {G00_ G01_ G02_ G03_ G80_ G81_ G82_ G83_ G83.1_ G84_ G85_ G86_ G87_ G88_ G89_}
:G2 = {G17_ G18_ G19_}
:G3 = {G90_ G91_ G90.1_ G91.1_}
:G5 = {G48_ G93_ G94_ G95_ G96_ G97_}
:G6 = {G20_ G21_}
:G7 = {G40_ G41_ G42_}
:G8 = {G43_ G49_}
:G10 = {G98_ G99_}
:G12 = {G50_ G51_ G54_ G55_ G56_ G57_ G58_ G59_ G59.1_ G59.2_ G59.3_}
:G13 = {G61_ G61.1_ G64_}
:G4 = {M00_ M01_ M02_}
:G7 = {M03_ M04_ M05_}
:G8 = {M07_ M08_ M09_}
:G9 = {M48_ M49_}
END:
CYCLES:
NPECK CANNED
NDEEP CANNED
TURN EXPAND
FACE EXPAND
THREAD EXPAND
END:
MACROS:
#N = {
$BLOCK:BLOCK
; If the block number reaches the max (according to RD274) start over
; Note: 'N' has no meaning in processing and is there for readability ONLY
IF ($BLOCK EQ 99990) THEN
SET $BLOCK = 5
ENDIF
#L = { [RAPID ? (G01_) / (G00_)] }
#FTYPE = { [FEEDTYPE ? (G94_) / (G95_) ] }
#X = { $X:XAXIS }
#Y = { $Y:YAXIS }
#I = { $XCEN:XARC }
#K = { $YCEN:YARC }
#AR = { $ARCRAD:ARAD }
#R = { ($CCLDIST:RPLANE) }
#P = { IF ($CDELAY NE 0) THEN ($CDELAY:DWELL) ENDIF }
#F = { [RAPID ? [FEEDTYPE ? ($FPM:FEED) / ($FPR:FEED)] ] }
#DWELL = { IF ($CDELAY NE 0) THEN (G82_) ELSE (G81_) ENDIF }
#RAPID = { SET [RAPID] = 2 }
#FEED = { SET [RAPID] = 1 }
#SPIN = { ($SPINDLE:SPIN) [SPIN ? (M05_) / (M03_) / (M04_) ] }
#SURF = { IF ( $SURF GT 1) THEN
$SURF:SURF
ELSE "S525"
ENDIF
#GCLW = {
IF ($USR11 EQ 0) THEN
(G02_)
ELSE
(G03_)
ENDIF
#GACLW = {
(G03_)
ELSE
(G02_)
ENDIF
#IPLANE = {
IF ([CRETRACT] EQ 2) THEN
(G99_)
ELSE
(G98_)
ENDIF
#CRC = {
; Only output G41/G42 if part surface is requested (PSPROG=2) which means the CNC
; has to offset the tool
IF ([PSPROG] EQ 2) THEN
[CUTCOM ? (G40_) / (G41_) / (G42_) ]
ENDIF
#CRCNO = {
($CRCNO:CRC)
ENDIF
#Q = { ABS($CDEPTH/$CNDEPTH):NDEEP }
#Q = { ABS($CDEPTH/$CNDEPTH):NPECK }
#UNSET = {
IF ((ABS($DELTAX) LT $USR8) AND (ABS($DELTAY) LT $USR8)) THEN
UNSETALL
ENDIF
END:
RULES:
:INIT = {
set $RAPIDFEED = 100 ; rapid feedrate
SET $USR11 = 0 ; Set to 1 if Proturn Arcs to be negated (dependant on tool)
SET $USR12 = 0 ; set for Arc direction fix for FRONT turret and TURN cycles.
SET $USR13 = 1.0 ; SCALE FACTOR TO COMPENSATE FOR ANGLES BEING WRONGLY SCALED IN INCH.
SET $USR14 = 0.0
:START = {
; start with N10, increment in 1s
SET $BLOCK = 1
set $INCR = 1
:ORIGIN = {
;#N (G92_) $ORIGINY:YAXIS $ORIGINX:XAXIS EOB
;unset :XAXIS
;unset :YAXIS
:RETRACT = { #N #L #Y #X EOB }
:UNITS = {
; G20/G21 = Inch/MM units
; G18 = XZ Plane
; G64 = Constant velocity mode (G61 = exact stop)
; G80 = Cancel modal motion (deactivates all move modalities)
; G90 = Absolute mode (G91 = Incremental mode)
; M49 = Disable speed/feed overrides
#N [UNITS ? (G21_) / (G20_)] (G18_) (G64_) (G80_) (G90_) (M49_) "G90.1 "
; KAA - changed order to default IN so that the set is not needed 2x for each IN
; Sets MIN change in move for a program block to be written
SET $USR8 = 0.00005 ; default IN scale
set $usr13 = 25.4
IF ([UNITS] EQ 1) THEN
SET $USR8 = 0.0005 ; set MM scale
SET $USR13 = 1.0
ENDIF
(G40_) (G49_) (G80_) EOB
#N #FTYPE #F EOB
:CUTCOM = {
IF (0 NE 0) THEN
ELSE
(G40_)
ENDIF
#CRCNO EOB
ENDIF
:GOTO =
NULL ; "DISTANCE : " $DISTANCE:NUM1 EOB
IF ($DISTANCE GE $USR8) THEN
#N #CRC #CRCNO EOB
#N #L #Y #X #FTYPE #F EOB
ENDIF
:GOCLW = {
#UNSET
IF (([PSPROG] NE 2) OR ([CUTCOM] LT 2)) THEN
#N #CRC EOB
#N #GCLW #Y #X #AR #F EOB
ELSE
#N #CRC #CRCNO EOB
ENDIF
:GOACLW = {
#UNSET
#N #CRC EOB
#N #GACLW #Y #X #AR #F EOB
ELSE
#N #CRC #CRCNO EOB
ENDIF
:DELAY = { #N $DELAY:DELAY EOB }
:NDEEP = { #N (G83) #Y #X #R #Q #IPLANE #F EOB }
:NPECK = { #N (G83.1) #Y #X #R #Q #IPLANE #F EOB }
:SCREWING = { #N "G32 " #Y #X #F EOB
UNSET (G5)
UNSET :FEED
:SCRCUT = {
UNSET :FEED
#N #FTYPE #F EOB
#N (G0_) #X #Y EOB
#N (G1_) $CXSTART:XAXIS $CYSTART:YAXIS EOB
#N (G76_) ($CYEND-$CDEPTH):YAXIS $XEND:XAXIS ""$FEEDANGLE:PA " "$PITCH:FS " "$ROUGHCUTS:DS " "$FINISHCUTS:PF " T0 " $SPINDLE:SPIN ""$CLDIST:PO eob
#N (G94_)eob
UNSET :FEED
:SPINDLE = {UNSET (G5)
IF ( [SPIN] eq 1) then
#N (M05) eob
ENDIF
IF ([SPINTYPE] EQ 2 ) THEN
#N [SPIN ? NULL / (M03_) / (M04_) ] #FTYPE #F EOB
#N (G48_) $MAXSPIN:SPIN " " EOB
#N (G96_) $SURF:SURF EOB
ELSE
#N (G97_) $SPINDLE:SPIN " " EOB
ENDIF }
:FINISH = { #N (M05_) (M09_) EOB
#N (M30_) EOB " " EOB }
:SELCTL = {
SET $USR11 = 0
IF ([TURRET] EQ 2) THEN
SET $USR12 = 1 ; Front Turret, set $USR12 for TURN cycles arc direction
SET $USR12 = 0
ENDIF
set $CYCLETIME = $CYCLETIME + 0.5 ; 30 seconds for a tool change
#N (M09_) EOB
#N "G00"" " $YSAFPOS:YAXIS $XSAFPOS:XAXIS (M05_) EOB
IF ($X NE $XTLOAD ) THEN
#N (G28_) $XTLOAD:XAXIS EOB
#N (G49_) EOB
ELSE
IF ($Y NE $YTLOAD ) THEN
#N (G28_) $YTLOAD:YAXIS EOB
#N (G49_) EOB
ENDIF
ENDIF
EOB
#N (G49_) EOB
:CYCLEOFF = {
#N (G80_) EOB
unset :G1
UNSET(M08_)
UNSET:RPLANE
UNSET(M09_)
UNSET :FEED
UNSET:YAXIS
UNSET:XAXIS
UNSET (G5)
UNSET :SPIN
UNSET :PECK
UNSET :DWELL
:GOHOME = {
UNSET (G5)
UNSET :FEED
UNSET :SPIN
#N "G00" " " $YSAFPOS:YAXIS $XSAFPOS:XAXIS #FTYPE #F EOB
END:- TomKerekes
With a custom screen normally the graphics goes to the GViewer on the custom screen. If you want to use the floating GViewer with your custom screen see here.i changed from my custom screen to the basic 2 axis lathe. got the tool path but of course the tool is backwards
I'm not sure what you mean. Maybe you have a Tool, Fixture, or G92 Offset that is non zero? You might add a dummy Y axis to the Coordinate System to display Y and view Machine Coordinates vs GCode Coordinates.my Y axis hovering tool in the g code viewer does remain though. i downloaded a new kmotion cnc on my office desktop and it does not do that
You might change try changing Lath Options | X Positive Front.G code and CAM preview
the red line is what the machine tries to cut
